timo888 wrote:My Caravel's thermostat is finicky.
At long last I figured out how the thermostat works - well sorta - and was able to fix it last week. Both, the "thermostat screw" outside and the On/Off switch activate the same microswitch at the inside. There is also a small screw at the inside (actually it's part of the On/Off switch unit) which just like the thermostat screw adjusts travel of the entire metal rod. Hence these two screws influence each other, meaning that my first attempts of setting the thermostat either activated or deactivated the On/Off switch permanently. Only with the correct setting of the screw inside the On/Off switch it was possible to adjust the thermostat as well...
Eventually I can turn my Caravel on and off with the switch and the thermostat activates the heating unit at around 90°C and deactivates it at 97°C...
timo888 wrote:It's the early 1960s and we're Arrarex engineers being told by the marketing guys that unless we come up with a way to steam-froth milk, Arrarex will go the way of the dodo. Do we abandon our beautifully simple temperature-stable open kettle and our gravity-fed stainless steel group? No, we take early retirement and tell the guys in marketing to take a ride on a rolling donut--whatever the equivalent Italian idiom would be.
That would be
vaffanculo in Italian, I'm afraid...
