First pull! Such a relief
Postby kuyote on Sat Sep 27, 2008 3:43 pm
Here is the story of my first experiance with my new baby.
I found a working europiccola, which looked like it was barely used. It was one that I could actually afford, so I snatched it up quickly. It included a portafilter, and a single basket but unfortunately, it didn't come with a tamper. I couldn't wait for my new tamper to arrive on Monday. So, in desperation, I dug through the spice cabinet. There, suddenly I saw a glowing aura surrounding a small jar of honey. To my amazement, it fit the portafilter perfectly!
I put a quick grind to my beans, and filled the basket with a couple teaspoons of grind. Inserted the honey jar, and pressed down, and twisted. Wow it worked! I slid the basket into the portafilter, proceeded to set the portafilter down on the counter, to make sure everything was set. Make note: Portafilters don't stand too well on their own. After picking up PF, and the now emptied basket, I found myself having to fill the basket and tamp again.
This time I didn't set the PF down. I inserted it into my pavoni, and waited for the water to finish heating up. I flicked the temperature switch to number 1, slowly lifted the handle, counted to 10, and started the pull. Around 1/4 of the way through the first pull, I lifted the handle back to the top, and slowly pulled down until it reached the end. There, inches below it, lay 2 small cups. They were now half full of the dark, nectar from the Gods. On top of it all lay a light crema, as if sent from heaven.
It was far from a perfect pull, however even now, I can see that this will be a beautiful relationship. Despite everything working against me, I can say it is better than anything I have had from a larger coffee chain who shall remain nameless.
kuyote
Postby zix on Sun Sep 28, 2008 3:20 pm
Congrats!
I still remember my first pull on the Vibiemme Domobar. That wow-feeling and slight dizzyness... Your post radiates it. Could have been me writing, only mine was on alt.coffee, and yours was much more eloquent.
That jar tamper was a good idea - must remember to try it out. It would be interesting to see what happens with a concave tamper. Wish you the best of luck, and feel welcome to join the LMWDP artillery (we should be since we are the ones that truly pull shots, right?)
LMWDP #047
zix
Postby peacecup on Mon Sep 29, 2008 3:15 am
I've been pulling shots almost exclusively of lever machines the past 3 years, and the espresso just keeps getting better.
PC
LMWDP #049
peacecup
Postby IMAWriter on Tue Sep 30, 2008 10:37 pm
zix wrote:Congrats!
Hopefully you meant "conVEX" tamper!
Rob
LMWDP #187
www.robertjason.com
IMAWriter
Postby zix on Fri Oct 03, 2008 1:29 am
No, I figured it as concave - unless Kuyote tamped his coffee with the lid of his honey jar, turning it upside down. But then it should've read "flat" :)
LMWDP #047
zix
Postby kuyote on Mon Oct 06, 2008 12:59 am
I guess I should have said mentioned how I used it, I did turn it upside down to use the flat lid. My rosewood tamper arrived from 1st-line a few days ago. It is a perfect fit for the double basket, and does a much better job. I decided to turn the portafilter on my lathe, so now I have a nice bottomless PF. Next up, I'm keeping an eye out for a decent inexpensive grinder.
kuyote
Postby noizy on Mon Oct 06, 2008 1:22 am
Tomorrow I'm going to the grocery store portafilter in hand and I'm gonna get myself a nice new tamper :lol:
noizy
