aindfan wrote:2. The lever has some side-to-side wiggle (about an inch left to right at the very edge of the handle). Is there a screw that I can tighten to prevent that? I see there are two pins where the lever connects to the piston and neither of those are secure enough to keep the lever perfectly straight and prevent the wiggling. I can still pull it down at shot pressure.
4. The pre-infusion: it seemed like I could make it most of the way down with normal (no coffee) resistance on the lever, but once I got back up the resistance was there. Is this normal, or is it likely that I'm waiting too long between the "flush" and "go" parts of "flush and go?" (Yes, I know, it doesn't matter if it tastes good, but I haven't pulled enough shots to experiment with and without the pre-infusion.)
roastaroma wrote:Re the stock Gaggia steam wand, you may get better results by leaving off the panarello sleeve and steaming with just the plastic tip. That way you can see the exact depth of the tip, which is crucial for decent microfoam. For latte art (with the Sirena, anyway), I find that 10 sec. of stretching is plenty; more than that, and you can end up with "bubbly" foam that doesn't pour right.
Alchemist wrote:OMG, and I just re-read that you are drying everything before the shot. No wonder you had to pull the lever all the way down - the head empties out. Clean up after the shot - not during.
aindfan wrote:I just finished a phone call with WLL to initiate a replacement of my Achille.
