GreatDane wrote: I have to figure out how to load video on this sight. I'll go ahead and load some still pictures. John and I went through more than a pound of coffee today! I must say, we had fun! Oh and I learned a lot!
arriflex wrote:WOW! I wonder if adding a little purge valve like the ones on tire pressure gauges might allow you to relieve the air pocket during pre-infusion and get a full shot.
For those of us without your lathe skills/patience, perhaps manufacturing a new piston shaft would be easier by taking an appropriate size and length of thick walled pipe and turning down to the proper dimensions. A set of threads on one end to match the existing (presumably metric) interface to the piston and we get to use npt on top so no custom adapter necessary there. That may also present an appropriate opportunity to change the interface with the lever (and fix your leak once and for all) by putting ears on the shaft rather than the through pin there now.
If I thought I could pull off the hole, I'd buy a spare shaft and go for it. However, I really don't have the confidence for that.
arri
