Alchemist wrote:You devil
I disagree with this. I may run through the compression numbers and give a theorectical distance/volume the water will go up the tube, but note I say water. The piston head is only going to see water until the very end of the stroke, and then, even if a touch of oil/water makes it up the tube, it will be the first expelled when the air column expands again.
As for cleaning, look at the hole I have drilled. Ain't no brush going to make it up the hole.
But this is an experiment, and field testing should prove out....
Judging from the relatively small amount of coffeeoil-crud and sediment that found its way into my Caravel's hollow piston, I don't think the problem will be a big one, but it would have to be part of the cleaning regimen. I have found ultra thin brushes in a surgical parts catalog that are used to clean out very small flexi-tubes. Not inexpensive, but would do the trick if necessary. Maybe even a pipe-cleaner would do.
Regards
Timo
