by peacecup on Sat Feb 16, 2008 1:57 am
If any of you followed the LM GS-3 thread where someone listed the problems with the mulit-thousand machine as delivered, us lever buyers would probably be considered lucky. I think in the espresso business there is a lot of manufacturer-vendor fine-tuning that goes on as buyers report issues with their machines. Frankly, I'd guess that Swiss machines are more likely to be built to perfection than are Italian machines. But there is an issue with cost...
All that said, its good that you posted the list, so buyers can be aware of potential issues. Especially because many have to buy sight-unseen through the mail.
RE: some of the issues,
My drip trays had sharp edges, which I filed with emory cloth. I reported it to Vanelis, who said they would correct it on their remaining machines. It also does not stay in the recess well, but I've just learned to work around it. I would like it to work better though, but since the catch tray is not removable, I use a catch basin anyway. I also prop the cup up on a spare filter basket when pouring a shot because the group is set so high up.
In reference to the rubber feet, the base is designed to sit lower in the back for balance during use.
RE: backward lean on the case I'm not sure how much so yours leaned, but Joe has seen lots, so he should know. But again, the rearward lean is, by, design, to balance the machine duirng use.
The noises while heating are definitely a concern, so hopefully your repairs found the problem.
It seems to me if Joe had noted so many problems with the machine he should have sent you a different one. I'm not sure I would be satisfied with having to disassemble a new machine before I could use it.
Dogshot got an Export a year or two ago - you could ask him if he had any issues.
During my many posts in praise of the design of the Export I've always tried to note that the build tolerances are not up to what I would expect from a Cremina. They are what they are, and its important that potential buyers get to read threads like this.
I hope when the dust settles you'll find that the Export lives up to your expectations,
PC
LMWDP #049
