mikemar42 wrote:
When I got the Cremina the boiler top did not have that small circular plastic sticker on the top. There is a metal dome exposed and a bolt. When the machine gets up to pressure the boiler top hisses and bubbles. What can I do to fix this.
mikemar42 wrote:Also, is it ok to leave any water in the boiler after pulling a shot. I usually empty all of the water from the machine, but I have been wondering if it would be ok to fill the boiler and just leave the water in there until my next shot. How long can you leave water in the machine ? I haven't done it but I have been wondering about this.
Dept of Health and Human Services; Agency for Toxic Substances and Disease Registry wrote:A survey of 1,484 drinking water samples taken from various districts of the American Water Works Service Company showed that average lead levels in a 1-L first-draw sample for copper, galvanized, and plastic pipes were 9, 4.2, and 4.5 microgram/L, respectively. These data show that even plumbing that did not use lead solder for copper pipes (e.g., plastic pipes) contained significant levels of lead, primarily from the brass faucet fixtures, which are used in almost all plumbing. The brass fixtures may account for approximately one-third of the lead in the first-draw water (Lee et al. 1989). Lead levels are also known to increase when tap water is heated in boiling kettles that contain lead in their heating elements. [emphasis added]
p. 331, http://www.atsdr.cdc.gov/toxprofiles/tp13-c6.pdf
