Faema Veloxtermo wall mount espresso machine
Postby rolleiman on Sun Jul 24, 2011 10:01 pm
Hi :
Is there anyone know whether this machine has steam function or not?
I got different answers after studying from the web, someone said yes, someone said no. I am guessing that maybe some model has steam function? some model has not?
Can anyone confirm that if you have this machine?
Thanks.
yuwen
rolleiman
Postby another_jim on Sun Jul 24, 2011 10:42 pm
I saw a model on Ebay three years ago that was designed for connection to the standard gas powered thermoblock instahots used in Europe in the 50s and 60s. It had no steam, and no heat source of its own. I do not know if they made it in other configurations.
another_jim
Postby wouter on Mon Jul 25, 2011 5:05 am
Hello Yuwen
On your picture there is a steam pipe on the top right
I used one sometimes and it steams, the boiler with heating element is in the group
It is a small boiler, so there iss not much steam in the boiler
EspressoStrietman redefines the craft of espresso making
wouter
Postby rolleiman on Mon Jul 25, 2011 5:19 am
Wouter:
Thanks for your help.
Is the steam enough for a cup of cappuccino?
Yuwen
rolleiman
Postby compliance on Mon Jul 25, 2011 11:01 am
Did you win the auction for that one? It went for a good price.
compliance
Postby 13thfloorelevators on Tue Jul 26, 2011 4:56 am
from my understanding the "steam wand" is just for hot water. no steam boiler included as the boiler is completely filled with water!
else the velox wall mount machines are great! congrats on the buy!
LMWDP #281
13thfloorelevators
Postby rolleiman on Tue Jul 26, 2011 5:48 am
Yes,I won that bid.
rolleiman
Postby orphanespresso on Tue Jul 26, 2011 7:02 am
I am sitting here looking at an identical but older machine on our wall. It is our "cold dead hands" machine as in you would have to pry it from our cold dead hands to get it away from us. Have used it for 2 years straight with no temptation to upgrade, or downgrade as the case may be.
You can use the wand or steam but you have to perfect the little dance that you have to do with the water inlet valve. The steam is pretty wet but after you pull the shot you simply close the water inlet valve and release steam through the valve to kick on the element and things will get pretty pressurized....then the overpressure valve starts to drip and you know you are now cooking with gas on the steam function....but the machine makes such good espresso that you will likely not want milk in the long run.
orphanespresso
Postby rolleiman on Tue Jul 26, 2011 11:41 am
Doug:
My wife is a Starbuck kind of guy.she drink a cup of cappuccino every morning, so I really need the steam. Thanks for your tip, that is the only detail descriptions that I have ever found on internet about Veloxtermo steam function, and that explain why Faema Veloxtermo DM declares that it absolutely has no steam function. (Enrico Maltoni's Faema book).
assolutamente senza vapore -> absolutely without steam
That is why this question is so puzzled. Seems like Faema designed this wand for hot water only in the original idea.
Thanks a lot.
yuwen
rolleiman
Postby 13thfloorelevators on Wed Jul 27, 2011 5:54 am
orphanespresso wrote:I am sitting here looking at an identical but older machine on our wall. It is our "cold dead hands" machine as in you would have to pry it from our cold dead hands to get it away from us. Have used it for 2 years straight with no temptation to upgrade, or downgrade as the case may be.
uhh...not sure if this is a good idea....dangerous because its possible to expose the heating element to air which might cause damage to it (and the heating element is not available anymore, so it would have to be custom made)....
LMWDP #281
13thfloorelevators
Next
