Faema President - clogged grouphead
TsurTriger
Postby TsurTriger » Jan 11, 2017, 3:03 am
Hello,
I have President 1Grp head that seems to be clogged.
The machine arrived very fast to 0.9Bar pressure in the boiler (around 20 minutes) but when I pull down the lever, there is very poor stream of water into the group head.
My water stream:
For comparison, other President water stream (from other Home-Barista member):
Someone has any idea how to fix it?
dominico
Postby dominico » Jan 11, 2017, 3:16 am
It looks like you posted the same video twice.
My guess is that your inlet valve is set almost closed.
That nut hanging down behind the group covers a valve which allows you to adjust the flow. The valve is very finicky, only a half turn between fully closed and fully open.
Here is a video I made to demonstrate how the valve works: As you can see the far group has the nut still in place, with the near group I have removed it to be able to adjust the valve.
http://bit.ly/29dgjDW
coffee & espresso equipment and accessories
Sponsored by Prima Coffee - coffee & espresso equipment and accessories
dominico
Postby dominico » Jan 11, 2017, 3:19 am
I'll also state that if the cause of your flow is indeed simply that valve, then a slow inlet flow is not necessarily a bad thing. I set mine low on purpose as I feel it works better for light roasted coffee to have the chamber fill more slowly with water.
TsurTriger
Postby TsurTriger » Jan 11, 2017, 3:34 am
Opps, you're right. I tried to post your video as comparison.
OK, I will try it as soon as I'll be back at home. I hope you're right. I'll update you.
Thanks, again 8) , for your very helpful inputs.
Paul_Pratt
Postby Paul_Pratt » Jan 11, 2017, 6:25 am
Yes I agree with Dominick, the flow valve may need to be opened a bit more. But the flow doesn't look too bad to me.
TsurTriger
Postby TsurTriger » Jan 11, 2017, 1:03 pm
dominico wrote:It looks like you posted the same video twice.
WOW, you rocks ! 8)
Works great. Now I know better my lovely President mechanism.
That adjustable pre-infusion is genius.
