www.baratza.com: skilled in the art of grinding
Faema Faemina
Postby AndersNygaard on Wed Jan 18, 2006 2:07 pm
Does anybody have information about the Faemina lever machine. Is it spring loaded? Can parts still be found? Anybody own and use one? What should I check before buying? What is that weird looking circular thing on the group head? (Google has lots of pictures). I was thinking of buying this machine for use in my summer house.
Thanks in advance
/Anders
AndersNygaard
Postby peacecup on Wed Jan 18, 2006 2:28 pm
Hi,
I have no personal experince, but have watched several of the old ones go on Ebay. They appear to be spring loaded, and to have a sight glass to view when the cylinder is filled, which might be useful. Some of them look very nice, and I wouldn't be surprised if they worked very well.
LMWDP #049
peacecup
Postby AndersNygaard on Wed Jan 18, 2006 4:10 pm
Is that a sight glass :o So you can see the spring work. How cool is that 8) Must own! The group head looks smaller than the spring loaded ones I have seen. Could be fun to try. Thanks.
Best regards
/Anders
AndersNygaard
Postby peacecup on Wed Jan 18, 2006 7:52 pm
I assume the sight glass allows you to tell when the chamber is full of water (pre-infused). My first lever machine is a new Ponte Vecchio, which has a 45-mm group (see the Ponte Vecchio thread). My best espressos so far have been single pulls which only produce about 1/2 oz. of coffee. If the Faema has a group this small you'll be limited to small coffees (part of the reason I went with the PV is that I wanted to go to more small, rather than fewer large, espressos). Another reason I went with the PV instead of a used lever like the Faema is condition and the availability of parts - I was afraid I'd end up with a restoration project for which parts would be rare.
If you do get one I hope you'll post the results!
LMWDP #049
peacecup
Postby fashla on Wed Mar 07, 2007 11:18 pm
Hi Anders,
I've just saw your post. I have a working Faemina. It's a really good machine. The only problem are the seals, they came like stone rubber, so i had to break them and clean.
Now im using some self made cork seals and it works fine.
Please let me know if you finally have a Faemina
Regards
fashla
Postby luca on Thu Mar 08, 2007 5:43 am
fashla wrote:Hi Anders,
Regards
I'm kind of looking at buying a faemina now ... could you tell me if it uses a standard 58mm portafilter?
luca
Postby timo888 on Thu Mar 08, 2007 11:10 am
AndersNygaard wrote:Does anybody have information about the Faemina lever machine. Is it spring loaded? Can parts still be found? Anybody own and use one? What should I check before buying? What is that weird looking circular thing on the group head? (Google has lots of pictures). I was thinking of buying this machine for use in my summer house.
Thanks in advance
/Anders
The Faemina is similar to the Microcimbali, which is still being sold by Cimbali, if I am not mistaken.
Regards
Timo
timo888
Postby fashla on Sat Mar 10, 2007 10:51 pm
Hi Luca,
I'm new on this subject, but the portafilter measures 54mm on the inside (where the basket lays). Hope thats the measure you were looking for.
Regards,
Fashla
fashla
Postby CremaKatz on Tue Sep 11, 2007 1:31 am
Hi All,
New to this forum, but not to espresso machines.
I have a Faemina in need of gaskets. I note that fashla
created his own gaskets from cork. Looks to me like
there are some piston gaskets and I can't imagine making
them from cork. I guess fashla only made cork gaskets for
the tank and portafilter?
A while back I posted an exploded diagram of the Faemina
that the kind folks at Faema sent me. You can find them here:
http://www.coffeegeek.com/forums/espresso/leverespresso/36497#36497
If anyone has a US source for a gasket set for this fine machine,
please do post it.
Fashla, what type or brand of cork gasket material did you use?
Is it certified food safe?
Thanks!
CremaKatz
Postby tcvt on Wed Dec 19, 2007 8:12 pm
I have a Faemina which I picked up at a Goodwill store for $5 about 10 years ago. It's looking more possible to get this working than it did ten years ago but I need a Portafilter. I haven't looked at it in may years and somewhere I have a portafilter from another machine that was a close fit but not a very good fit.
Tom
tcvt
Next
