by Tom@Steve'sEspresso on Mon May 25, 2009 12:05 am
Thanks Mark, absolutely!
So today I went down to auto zone and behold, spray-on engine enamel- good to 500*. Spent a few hours this noon stripping all the old lacquer off the boiler and the grouphead. I found that 3M safe stripper worked magic on the old yellow peeling stuff. Managed to polish things up nicely and then got a new coat of the enamel on. Doesn't look nearly as nice as factory stock but I think it'll do a good job of protecting the plating and brass until such time that I can have a real electroplate done. Took a little while to get everything reassembled with a few snags here and there. The pressure gauge wouldn't line up back to original so out came the teflon tape. Tried to crack the outboard side of the steam valve but the damn thing wouldn't budge! This after a few glasses of La Crema though, so maybe I was slightly impaired- hehehe. Sightglass needed a little coaxing as far as screwing in the mounts. Remember that the hubs are a little tweaked out of alignment so I tried to be very careful as to not break, crack, or strip anything.
Everything looked good for ignition at this point so I put it up on the stove to see if the Pstat was going to leak under pressure, etc. Filled it up, capped it, and flipped the switch...Got lights, got rumble, got heat!
Gauge started moving; higher; higher; almost .8bar. Bled false pressure off. Gauge rebounded quickly. Got a nice drip going from the Pstat gasket. Gauge climbing past 1.1...continued out of the red brew zone), still going. Killed the switch at 1.25. No need to risk it on the first run. All this within 7minutes of flipping the switch. Wow! I'm impressed, as the element struck me as a bit small. And the steam was strong and dry just like everyone else says, very nice.
I'll get some fresh beans in the morning and pull a few real shots. Suppose I'll have to modulate the power manually until I get the gasket repaired. And I'll get the other pics up as well. All's left to do now is get a brass drip tray and a new base, then the MCal will be a complete machine again. YAY!!
Off to bed now
#222
LMWDP #222
Pharos #53
Live graciously
Be kind
Have fun
