by Randy G. on Sat Feb 13, 2010 11:13 pm
Hard to say what it was from the pic.. Did the entire pipe rotate to screw into the heating element?
yes, it is possible to "un-braze." the simple explanation is that brazing is high temperature soldering, usually using brass instead of a lead-tin alloy.
The solution depends on what the other end of the pipe is, how complex the pipe's bends are, and how close it has to fit. My thoughts at the moment would be to install a fitting in the heating element (possibly tapping the hole to a larger size), and using a compression style fitting, maybe like on brake lines (double or single flare).
IIRC, to bend tubing that way it is filled with a melted salt, that is allowed to harden, and the pipe then acts like a solid rod when being bent. The pipe is then heated again and the slat runs out... I think my dad who was a machinist told me that... Maybe not..
