by orphanespresso on Tue Apr 14, 2009 1:05 am
Yes, perhaps you are expecting too much from it. Gaskets are meant to wear out so that the metal parts don't. La Pavoni recommends the gaskets be changed every 2 years or less. All machines will have some level of gasket wear. But, as far as the leaks go, the Pavoni wand seal seems like it's not a real well engineered part. There is a hard plastic bead in it, and the gets harder over time - not very flexible even at the beginning, but it was their solution to sealing the steam wand. All manual levers require a bit more periodic maintenance than they often get - steam wand seals should be lubed occasional, as should the cylinder (cleaned & lubed on a regular basis), and that would extend the life of the parts. Sort of like a car - if you never change the oil, or replace the filter, it just won't last as long... Some makers have been using Teflon and Goretex in the seals to attempt to make them last longer, but I don't know if that really works, or if the longer life justifies the higher cost for them. The La Pavoni is a very user friendly machine as far as replacing the parts yourself - a few simple tools are needed, and a little time & patience, but once you've done it, the next time is much easier. Except for the REALLLY old Pavoni's there is pretty much still full parts support - more than can be said for many newer machines! If you like your Pavoni, and can make good espresso for yourself with it, I'd say keep it up! You can buy a LOT of seals for the price of a new machine!
