samgiles wrote:I had exactly the same thing happen to me so I feel your pain.
http://www.home-barista.com/levers/euro ... t7498.html
I actually tried firing my one up which was probably a little foolish. I got steam escaping from both where you've shown and also the base of the steam valve assembly
Fullsack wrote:If it is of any comfort, my frequently used Europiccola had a bent steam shaft connection. I did the same fix and I'm still here to tell the tale.
KnowGood wrote:I've run it about a half dozen times or so, looking at every connection carefully and can safely say that it is working as it should.
