www.baratza.com: skilled in the art of grinding
Europiccola blowing bubbles
Postby roadman on Fri Sep 16, 2005 2:02 am
First off I just want to say it's delightful to have found a forum for lever machines. What a great idea!
I was recently gifted with my first ever espresso machine, a used pre-Millennium La Pavoni Europiccola. It was leaky so I replaced the seals on the group and the steam shaft. So far so good. It worked well through about 3 - 4 months of light use... until now.
Now about midway into the pull my nice steady stream of espresso turns into a ribbon of bubbles. There is a post with pictures about this on CG, though after reading it I'm still not sure how to correct the problem. http://www.coffeegeek.com/forums/...o/questions/165652
Anyone have a clue about what's going on here?
I'm using fresh beans from different roasters, I'm tamping and dosing properly and I have a good grinder.
Could there be a problem with the seals? It seems a little early for seals to be failing, but who knows, I may have unduly stressed the seals while I was on the steep part of the La Pavoni lever learning curve.
Jon
roadman
Postby Kaarina on Fri Sep 16, 2005 4:52 pm
Hi,
I have a rather new Europiccola and I get this every time. I haven't minded much, since I have had other challenges to concentrate on - like first getting no decent crema, then not getting decent microfoam - I have just snagged the cup away and let the foam go to the tray.
One idea - why don't you go to the Pavoni website and send them an email? I got an answer to one of my queries - albeit with a couple of weeks delay.
I would also love to hear if there is something to be done about this foam. If not, then we have to take a Gallic attitude :-)
best regards Kaarina
Kaarina
Postby Paul L on Sat Sep 17, 2005 2:29 am
Since I started home roasting I get this amazing looking liquid flowing through the pf, the darkest most striped crema I have ever seen right the way through the short shot that a Pavoni double basket produces. Wonderful. However, at the end of the shot I also get the larger bubbles. I have read that it is a feature of fresh coffee which has not degassed enough although I am still finding this on 5-day old roast and so I don't know, it's too early for me to tell. I know I read somewhere that the pressure profile of a Pavoni pull is that it achieves the required 9-bar through the shot until that last bit when the preesure drops to 7-bar. Basically the part where we see the bubble. Perhaps there is a connection.
Coffeetime (UK) Greens Club
http://coffeetime.wikidot.com/
Paul L
Postby luthier on Sat Sep 17, 2005 2:31 pm
Maybe some manual pre-infusion (push the lever up and down for a few times) will help?
You've been perfecting your technique for a long time...... So have I.
luthier
Postby srobinson on Sat Sep 17, 2005 4:10 pm
Jon, let me give this a shot. From reading your post, it looks like you replaced the gaskets...everything was looking fine and this has only started recently. Symptoms are very close to what I ran into the first time I took my Pavoni apart. What I think is happening is this:
1) When you replaced your piston gaskets you might not have screwed the piston back on the shaft tightly.
2) If not, then over time it will slowly unscrew and the piston will start to partially block the water inlet hole
3) As such you may not be getting a full amount of water in the grouphead thus
4) you will have a soft pull at the top of your stroke and you will be pulling some air at the end of each shot.
I would suggest that you take your grouphead off and pull the piston to make sure it is very tight on the shaft. If everything is proper then you should hear close to a click at the top when the water fully rushes in. You should have a firm pull from the start.
I would give this a look before I start chasing some of the suggestions that I saw on the CG thread.
Let me know if this works
Steve Robinson
LMWDP #001
srobinson
Postby srobinson on Sat Sep 17, 2005 9:53 pm
2) If not, then over time it will slowly unscrew and the piston will start to paritally block the water inlet hole
I would suggest that you take your grouphead off and pull the piston to make sure it is very tight on the shaft. If everything is proper then you should hear close to a click at the top when the water fully rushes in. You sqhould have a firm pull from the start.
Steve Robinson
LMWDP #001
srobinson
Postby roadman on Mon Sep 19, 2005 1:30 pm
Thanks for your replies.
It's been one of those days. First thing in the morning, the bristles started dropping out of the brush I use to clean the group. Next the toaster went belly up. Then the stereo. Looks like the beginning of a full scale appliance revolt, but I press on.
Steve suggested I check the piston on the Pavoni. Sounded plausible. To be thorough I decided to de-scale the machine before opening it up. Used vinegar. Now it acts like the seals are truly shot - no pressure, zip, nada. Took apart the group.
Aha! Didn't know it but the retaining ring in there was starting to rust through, the vinegar pushed it over the edge and it snapped. Figured this was the problem. Happily headed out to the auto parts store for a spare, came home and installed the new ring. Put it back together and zip, no pressure again.
Now I'm waiting for a new set of seals to come in. I will post an update after the seals are replaced. Hopefully at the end of all this the bubbles will be gone.
Jon
Ps to Steve - the piston and the shaft were tight, my guess at this point is that the seals were just starting to go. When I first got the machine I choked it fairly often by using too fine a grind. Unfortunately I also continued to force the lever down even though it was locked up. I'm guessing this has been pretty tough on the seals. Probably won't be doing that again anytime soon.
roadman
Postby srobinson on Mon Sep 19, 2005 2:58 pm
Are you getting any water in at all? Are you hearing that click at the top of the pull?
Steve Robinson
LMWDP #001
srobinson
Postby roadman on Mon Sep 19, 2005 4:19 pm
I'm getting water in but the steam coming out of the steam arm is anemic and I have to pump the lever up and down like mad to get to get water through the group.
At the top of the pull I'm feeling a click but not hearing it.
Jon
roadman
Postby Kaarina on Mon Sep 19, 2005 4:29 pm
Hi,
I asked Pavoni directly and they said the big bubbles mean the machine should be readjusted by the service center, as this indicates a problem with the pressure switch.
Kaarina
Kaarina
Next
