by RayJohns on Thu Dec 22, 2011 2:18 pm
I have three baskets for my 49mm La Pavoni. The one which came with it (the medium size one) holds about 12 grams comfortably.
I also have two baskets, which I bought from Stefano's. They are technically Elektra baskets, but they work on the La Pavoni. The single shot elektra basket is necked down at the bottom and works well for 7 to 9 grams of coffee. The double shot basket will hold up to about 16 grams and leaves plenty of head room between the top of the puck and the dispersion screen. Might even be able to get 17 or 18 grams into it if you really tried.
The double shot basket is nice, because you can pull a really rich shot. The single shot basket is good too, since it allows you to use 7 to 8 grams off coffee, if you want to do the traditional 7 grams to 1 oz of water.
The double shot basket is a few millimeters deeper than the normal La Pavoni basket and may or may not fit into the portafilter handle (if you have a naked portafilter, then it's no problem of course).
Ray
