by cbxl on Thu Dec 27, 2007 6:42 pm
Hello,
A head-scratcher of a La Pavoni problem. Any assistance would be lovely. Here's the deal: My coffee is too cold. It comes out undrinkably sour.
I'm pretty new at this espresso thing, but possessing an incurable masochistic streak and a desire to tinker with mechanical objects, I bought a Europiccola off of eBay. The machine arrived in pretty good shape. The seller said it had been bought by her grandmother, used a few times and stored in the attic, etc. etc. The usual story. Probably true.
When I first got the thing, I pulled a few blank shots and noted the distinct odor of rubber in the water and little black bits that didn't appear to be coffee suspended in it. Not good. I tried it with coffee and got a sour brew that was way too cold. There was a fair amount of crema. I figured the rubber smell meant some seals were failing, so I got a set and replaced everything except the gaskets connecting the sight glass tube to the boiler (I couldn't get my wrench in there) and the boiler-to-base and heating-element-to-boiler seals (I need a tamper-resistant Torx bit to get the base off--haven't found one yet). I followed the instructions at pavoniexpress.com.
The seal replacement went well, and the few random hissings and bubblings (particularly in the sight-glass tube) that I'd noticed before went away. But the espresso is still sour, still not hot enough.
I don't know where the problem is. Perhaps someone with a keener, more experienced eye can spot it.
Here are some details:
Machine: La Pavoni Europiccola, post millennium (one switch)
Coffee: stuff from a local roaster, pretty darn fresh
Grinder: Gaggia MDF; I've tried a few settings between 3 and 6.
When I turn on the machine, it takes about 10 minutes for the green light to go off. At that point, I can hear the water bubbling away in the boiler. There is some noise from the pressure-release valve, but there's no visible steam coming out of it, and the noise is not constant.
If I open the steam knob, I get a whistling gusher of steady, hot steam. I'm unable to make potable coffee, but I've at least made some great hot chocolate with the steam wand...
Technique: I've tried both the single and double filter basket. No discernible difference in temperature. I fill the machine to at least 3/4 full. I turn it on and wait for the green light to go out. I pull a blank shot with the portafilter and basket in place. I remove the portafilter and basket.
I fill the basket pretty well and tamp it down to about 1/4 inch below the rim. (Yes, I'm using the frustratingly small stock tamper.) I lock the portafilter in place and lift the handle. I can hear water coming into the group head. No coffee drips out when the handle is fully up, no matter how long I wait. (The manual suggested I'd start getting coffee after about 10 seconds.) As I push down on the lever, no coffee comes out until the lever is about halfway down. Then it starts coming. The resistance is not very great--I can push the lever with ease, but it certainly wouldn't go down if I didn't push. I don't have to lean on it or anything. Once the handle is all the way down, coffee continues to come out for a few more seconds. It usually starts pretty black and ends with a brown crema foam. The crema is OK--if I swirl the coffee around, it stays mostly put and coats the glass. The mouthfeel of the coffee is pretty thin, though. It is very sour; not terribly bitter.
The temperature of the coffee as it arrives in a pre-warmed cup is about 130 degrees F, measured by a digital probe thermometer.
If I leave the portafilter in place and pull another shot through the used grinds, the resulting temperature is around 160 degrees. If I take the filter out and just measure the temperature of the water as it leaves the grouphead, it is above 190 degrees, as best as I can tell.
But if I put new coffee in the basket and pull a shot, we're back down to 130 degrees, or maybe a bit more. It doesn't seem to help if I let the machine warm up longer, and the second and third shots aren't noticeable hotter than the first.
I'm truly puzzled.
Any thoughts?
Thanks.
