Elektra/Pavoni side by side - Page 3
Postby Bubble_Boy on Thu Jul 28, 2005 1:17 am
Since the wife was out to dinner, I figured I would stage one of those very sophisticated HB tests that women would categorize as a genetic male flaw should they observe it. I decided to do a pull using the bathroom scale.
Steve,
I found your comparison of the Lever Machines really Funny, as well as extremely informative.
Your writing style is easy to follow and your sense of humor is totally hilarious.
Definitely write up some more stuff when you have time.
Craig
Bubble_Boy
Postby jd576 on Thu Jul 28, 2005 10:24 am
The problem is I need to cut the bottom off the Pavoni portafilter before I can get my larger basket to fit in. Espressoparts.com will do the job of cutting a portafilter to bottomless for $25.
As you probably know, with the 51mm portafilter one cannot fit anything larger than the the stock double basket (which holds just over 12gm). And the Pavoni portafilters cost about $75 -- so it is an expensive experiment.
I am also told that "no one" now makes a 51mm basket except Pavoni -- the bigger ones I have are from an old Krups steam espresso makers I bought in the mid-1980's.
Maybe I am crazy, and it will make no difference -- or maybe I will not even be able to pull a shot through the bigger basket! Your comments above, however, make me think it is worth a try. Suppose I will have to spend the money and find out, or just continue wondering about it!
jd576
Postby srobinson on Thu Jul 28, 2005 2:25 pm
Craig, thanks for the vote on my writing. Many times these are done late at night in a caffeine infused haze and you question whether they make sense at all.
There is a nice thread on the A3 ...in the Bench forum if you want to see more of my rants.
Steve Robinson
LMWDP #001
srobinson
Postby srobinson on Thu Jul 28, 2005 2:33 pm
jd576, Now the HB team would never discourage one of our readers from spending $100 bucks in the pursuit of better coffee, I understand that it may be a bit much for this experiment.
Dan and I talked about your post last night and just were puzzled over your desire for 3oz pulls. The more I use these machines, the more I tend to go the other direction...pulling ristrettos. One of the most sublime coffee I have made have been a single pull with the larger Elektra basket on the pavoni.
As with many things in life we are stuck with the size of things that god gave us and in this case you can either perform the portafilter surgery or pull some smaller shots. Do a single pull with that 51mm original filter with all the steps right and tell me how that tastes. I would take two of those any day over a 3oz that I would categorize as a caffe crema.
Steve Robinson
LMWDP #001
srobinson
Postby jd576 on Thu Jul 28, 2005 7:47 pm
srobinson wrote: One of the most sublime coffee I have made have been a single pull with the larger Elektra basket on the pavoni.
There, you said it again! Add that to your previous tormenting words:
srobinson wrote: Those of you who have ever used the Pavoni understand what it means not to get an additional 25% more coffee in the filter and being able to pull some real doubles with 16.5 grams...
I just have this impression that with a bit more coffee in a bit larger basket, I would be able to pull a bit better shot. Size is not the issue entirely. (I think I read that in an old issue of Cosmopolitan...)
I only pull one shot in the morning. It's my daily ritual of coming to terms with "awake". Been doing it the same way for 15 years. And I enjoy doing it with my new partner, the Pavoni -- it is a simple, elegant machine. But I want that one shot to be really good, and just a bit bigger.
jd576
Postby Teme on Sun Jul 31, 2005 11:58 am
srobinson wrote:Let me know if there is interest out there on more threads on levers, process, and the science behind them etc since I tried not to cover ground that is readily available on other sites.
These are both great machines and if you have not experienced a lever then you should. They are both elegant solutions in tackling the complexity of making espresso. While they are not simple to use, I do not view them as out of reach to begin to master by any skill level. You will learn a lot about your skills and in turn be able to apply that to all of your barista endeavors.
A great thread Steve and a very interesting read as I am actually thinking of buying a lever machine. I thought of posting here but started a new thread on a few questions that I have.
Br,
Teme
Teme
Postby KarlSchneider on Mon Aug 01, 2005 9:04 pm
srobinson wrote:jd576, The more I use these machines, the more I tend to go the other direction...pulling ristrettos. One of the most sublime coffee I have made have been a single pull with the larger Elektra basket on the pavoni.
Steve,
As an authentic amateur at lever machines I decided a few days ago to work on shots made with a single pull. My mere one week with my Elektra tells me to agree with your suggestion here.
I also seem to notice -- on very little evidence that my old habit of preferring dark roasts is turning the other direction too with the Elektra. Just tried a lighter 2-day old roast and I could taste more of the details of the flavors.
Alas off on another trip that will interrupt my espresso studies.
LMWDP # 008
KarlSchneider
Postby srobinson on Mon Aug 01, 2005 11:58 pm
Karl, you see I am going to warp you. You came to me seeking Cafe Cremas and you are already into the multi-layered depths of ristrettos. I am sorry to inform you but White Zinfandel and Merlot will no longer work for you. You are into Pinot range now...and fortunately you have all the tools to take you to the next level.
Now when are you going to send me some homeroast so I can check out your handi-work?
Steve Robinson
LMWDP #001
srobinson
Postby KarlSchneider on Sat Aug 06, 2005 3:33 pm
srobinson wrote:Karl, you see I am going to warp you. You came to me seeking Cafe Cremas and you are already into the multi-layered depths of ristrettos. I am sorry to inform you but White Zinfandel and Merlot will no longer work for you. You are into Pinot range now...and fortunately you have all the tools to take you to the next level.
Steve,
Minor correction. I have a wine cellar of ca. 1000 bottles (including many fine red burgundies) collected over many years. Have not had White Zin in years. Never bought one. Tonight will open a 1990 Chianti Monsanto Il Poggio.
My interest in espresso dates from long ago but only have had the machines to do it myself since 2002.
Send me your address and I will gladly send you some home roasted coffee. Just did two batches today -- a North African blend (SM's Moka Kadir) and Ethiopian Harar Horse. I don't have much Cental American green stock but several Ethiopians, Yemeni's, Brazil's and Sumatrans. Want an SO espresso or an espresso blend?
LMWDP # 008
KarlSchneider
Postby ladalet on Fri Sep 02, 2005 2:28 pm
Steve,
I was wondering the technique you use to pull a double on your LaPavoni. This is where I run into the most trouble. I sometimes start to lose crema and get blonding after lifting the lever for the second pull. The most commonly used technique taught is to pull the lever all the way down for the first shot (less for ristretto), lift it all the way back up, and then all the way down for the second. This usually destroys the seal between the puck and the basket or break the puck for me. So, I make 2 short pulls about 1/3 the way down followed by a full pull. This works most of the time, but the act of doing the second pull seems to be a major weakness of home lever machines. I would really appreciate your input and hearing your technique.
Thanks in advance,
Lance
P.S. I asked Cannonfodder the same question. Perhaps having 2 posts within the lever post for frothing and shot pulling techniques and pictures would be good.
Lance Goffinet
LMWDP #019
ladalet
PreviousNext
