KarlSchneider wrote:In the midst of a too slow anticipated single pull I suddenly did a second lowering and release of the lever. The resultant shot was certainly better than what I would have had if I had waited longer for the single to complete. I conclude that time of push/pull is the more important factor on a spring-lever machine.
I am curious if other spring-lever users have had the same experience.
KS
Congratulations! You have independently re-discovered the 'Fellini Move' as discussed here some weeks ago ...
Actually, all sarcasm aside, I do believe that for this class (e.g. Elektra, PV, Bezzera) of spring-lever machine, a correctly executed 'double-pump' move can have some real benefits.
One procedure that I followed for years was to to a short 'bleed pull' through an empty PF/basket immediately after bleeding off the false pressure bubble in the boiler - on the theory that air/steam bubbles could also be present in the grouphead, and to further pre-heat the PF/basket before unlocking and constructing my shot.
I also believe that these machines have a pretty rapidly declining pressure profile as the spring releases, so by performing a 'double-pump' you are effectively purging the grouphead of any residual steam (it goes back into the boiler), and bringing the piston back down into its most effective pressure range.
Essentially, the shot now becomes a three-step process:
1) low-pressure pre-infusion with the lever held down, and water slowly entering the puck
2) Moderate-pressure infusion with the lever slowly rising, the puck flooding with water and expanding
3) Full-pressure extraction with the water flowing at the correct rate and temperature through the puck
As with all espresso techniques, timing, tactile feedback, and acute observation are critical to your success - I like to hold pre-infusion until the first drops have appeared, than gently (very gently, you don't want "to shock the coffee into submission") allow the lever to rise until the liquid emerging isn't just dark and viscous, but has a few crema bubbles - then briskly lower the lever, hold it down for a 3-count (one-thousand and one, one-thousand and two ...) to allow the water and puck to stabilize - and finally, release the lever, allowing the shot to complete.
One thing to watch for - especially with the rather limited dosages you enjoy - is that the shot can rapidly blonde towards the end of the pull. Keep a sharp watch, and be prepared to yank the glass immediately if you note any color change in the last third of the lever's stroke.
For giggles, you may want to consider trying this process with a full-sized basket - in which case I will also note that the 'mustaches' who taught me also recommended not placing the cup until pre-infusion was complete, as they considered it to be "too strong with the wrong flavors" - you may find that by throwing off the early and late portions of the shot that the sweetness, richness, and intensity you seek is present in full measure.
Cheers
Jim
