Elektra Microcasa a Leva questions - Page 2
Postby michaelbenis on Mon Jan 31, 2011 5:26 am
Glad the manuals helped. You can pul the plastic cover off the pressure gauge and then pull of the needle - very gentle and straight off, then pop it back on in the 0 position with the machine off. Thi is covered in more detail, with some other info you may find helpful here:
Can you revitalize a manometer?
and here:
Elektra Microcasa pressurestat problem?
The second thread will give you some good ideas about what you need to do to get your Elektra working at its best.
Cheers
Mike
LMWDP No. 237
michaelbenis
Previous
