HB wrote:No, it comes with both a single and double. You can even get a custom travel case:
image: http://www.home-barista.com/images/elektra-microcasa.jpg
Pictured in the corner
But if I were to do it again, I would skip the case and use the very nicely constructed original shipping cardboard box. As nice as the travel case looks, it adds a lot of weight. On the other hand, it does work nicely as a small end table.
Although I do not have the travel case I can agree with Dan that the standard cardboard box is very substantial and the travel case is not needed unless you plan to be a travelling rock-star espresso barista. I would also save the $$$ and get instead a good grinder if you don't have one and/or a good 49mm tamper. A plastic tamper is included with the single and double baskets but it deserves replacement before all else.
Tonight I had comparison shots on the Elektra and Cremina. The coffee is a 5 day old Yemen Sana'ani. Today or yesterday was the peak. Once again the essential difference between the machines was obvious. The Cremina heats up faster so the first two shots were from it. Wonderful texture and amazing finish in the taste. I did not think he Elektra could surpass this. But then I had two Elektra pulls. Where they truly excelled was particularly in the first part of the taste. So much more clear and focused. Actually they were less good in the second half. But the highest level of all was in the beginning of the first two Elektra pulls. Wine analogies abound: Volnay not Pommard / Medoc not St. Emilion / Pauillac not St. Estephe / Hermitage not Chateauneuf-du-Pape.
KS
