Elektra Microcasa a Leva keeps overheating
Hello guys.
I have been having problems with my Mcal.
The pressure just keeps building up.
I descaled it with vinegar diluted to 4.5%
Started it and the pressure just keeps going up.
I dont know if the gauge is broken, but when no pressure is it is in 1.5 bar, but when I heated the machine it just kept going and going.
I bought it this way, but want to get it working
So, to clarify, you mean that when the machine is switched off and cold the gauge reads 1.5 bar? Also, you most likely need to either clear the pipe that connects to the pressurestat, or the flexible membrane in the pressurestat needs replacement. Do post some pics so that we can try to help you more easily.
LMWDP #222
Live graciously
Be kind
Have fun
Live graciously
Be kind
Have fun
I will get some pictures tomorrow.
It got pretty scary today. The gauge was showing like 3.5 bars :O
- drgary
Be careful, please. Until you figure this out I wouldn't leave it one unattended and would shut it down if it gets too high.
LMWDP#308
LMWDP#308
- doubleOsoul
Yes, be careful. That is way too much pressure - anything in the red is for the MCAL. You might need to have a look at the pstat contacts which will tell you if you need to replace the pstat or not (which I think you will).
www.soulsidecoffee.com LMWDP #354
If it is reading 1.5 bar at 0, there has to be a good chance the gauge is simply broken. I say buy a cheapo gauge of amazon to test it out and see if you just need to invest in a nicer gauge or replace other parts
So if the machine would be working. How high will the needle go?
- rpavlis
Pressure gauges sometimes get "messed up" on machines without a vacuum relief. One can read pressure through the steam wand, however note that its thread is M6x0.75, not M6x1.0, should you try to connect a gauge in place of the steam tip. Gauges are also available with tubing that can be slipped over steam tips.
Elektra provides stern warnings about water quality with their new machines, because the design does not tolerate water impurities. They refuse to honour guarantees when failure results from ignoring the warnings that they supply. Impurities can lead to severe pitting of the upper part of the group that can render it useless. You could have deposits in the tube leading to the pressurestat if low quality water were used in this machine.
It is difficult to observe the inside of the MCAL boilers because the cap is small, but you can get a special light manufactured for fire arms enthusiasts that is designed to help them look down barrels of rifles and shotguns.
Remember you have a bomb when both the pressurestat and pressure relief valve fail! This is a very serious matter!
