I've got a Micro Casa Leva that I bought new in 2005, and I'm trying to sort out a problem with water appearing inside the base.
I took the base off recently to check the pressure switch, and discovered a lot of corrosion around the lip, and on the electrical connectors. Initially I thought some water must have got in either from leaving the machine standing in water at some point, or through the screw hole under the drip tray.
Cleaning the electrical connectors solved the intermittent problem I was having with the pressure switch, and I cleaned as much of the corrosion off the brass as I could, and left some silica gel sacks in the bottom to absorb any random moisture and minimise further propogation.
However, checking things again a couple of days later, I found some water in the base when I removed it, and looking more closely I realised that there was corrosion around the nuts that secure the heating element, and some moisture in that area as well. My first thought was the pipe to the pressure switch, however looking at the corrosion patterns it looks more like water has dripped on to the pipe fitting from above. I slackened off the pipe fitting to check, but the seal looks fine.
I've now removed the bottom plate of the boiler, and as far as I can see the o-ring is fine, and there are no marks on the brass to indicate leaks around the o-ring. Which leads me to suspect that one of the heating element connections might be the culprit.
I've removed the heating element nuts, but I can't see for sure how the seals work - it looks like there may be some kind of hard compound sealing the join, and the nuts might just be for mechanical strength. It also looks like getting the element off the bottom plate would be a pain, and putting it back might be even worse.
Does anyone have any thoughts or insight on what to do next? Should I just replace both the element and the plate, or is there a way to check and renew the seals?
