Elektra Microcasa 1984 Pressurestat Adjustment??
Postby DJR on Wed Jan 04, 2012 8:10 pm
If someone can advise me as to how to adjust this pressurestat, I'd greatly appreciate it. The machine as I got it is at about 1.7 bar.
So any advice as to what screw to turn, what direction and in what increments (half turn etc.) would be great. Specifically, I assume I have to turn the big nut that goes around the plunger pin that goes into that electric switch, right? Or is it a lock nut and I turn that little protrusion?
The machine was used as a display in Victoria Pastry in San Francisco.
Thanks,
dan
DJR
Postby allon on Wed Jan 04, 2012 8:29 pm
Just a guess, I'd turn the nut counter clockwise.
If the nut compresses a spring that the pin pushes against, you'd want it to be looser.
Note here:
Elektra Microcasa pressurestat problem?
stefano65 wrote:It is very important that when you descale a MC leva or SemiAuto
remove the pressurestat and flush the Pstat pipe as well,
because of the positioning and curve of the pipe there is a good possibility that "sediment" will seat in the curve and still disturb the functioning of the Pstat
I'd check that out too...
LMWDP #331
allon
Postby DJR on Wed Jan 04, 2012 11:26 pm
That did the trick. I had to turn it about one turn to get it to .9. It took just 5 minutes. I'll try it tomorrow am.
By the way, my rubber base is not attached with a screw; it come off easily.
Thanks,
dan
DJR
