Anyway, completely unrelated, but I've been lusting after a Cremina. Question: do they have the same proclivity to sneeze that the Pavonis do?
HB wrote:The Ponte Vecchio Lusso does not have a brew chamber pressure release mechanism; if you remove the portafilter before pressure has leeched away, it will be blown off forcefully by a messy mixture of very hot water and coffee grounds, a phenomena referred to as the "portafilter sneeze". Either wait three minutes before removing the portafilter, or try this trick:
Push the lever just short of half way. This will introduce air into the brew chamber and relieve the water pressure, avoiding the dreaded portafilter sneeze. Confirm the pitcher is underneath the portafilter to catch the last dribbles and unlock it. There will be a small puddle of water on top of the puck; turn the portafilter over the sink to drain and knock out the wet puck into the knockbox.
rawman wrote:Doesn't raising the lever pull air through the wet puck making cleaning the screen (and piston) harder to keep clean? Or, is it just a slight lift?
