by chopinhauer on Tue Aug 03, 2010 9:13 pm
I've had a Cremina (73 model) for 4 years. After installing a new set of piston seals I have not had to change them once (unlike with the Pavoni europiccola, that required new seals every year of so, otherwise it began to leak). So, no leaks, means, no new seals are required
BUT you do need to lube the seals in and around the piston every 3 or so months if you want to get decent and smooth performance. To do this, I can't see any other way than getting the piston out of the group head and lubing the seals and lubing the group a bit too. It takes about 20 or so minutes all up, so it isn't a big deal, but certainly worth it for the extra smoothness of the piston action that results.
LMWDP #027
