www.veniacoffee.com: purveyors of specialty coffee and exceptional equipment
DIY-Olympia Cremina piston rod seal "tool" and Fix
Postby mogogear on Sat Mar 24, 2007 7:12 pm
Ok, this is not fancy but they are available just about everywhere. You can come up with your own interpretation very easily. I had been thinking about this when I saw Bob Craig's post and went "AHAA!"
If tape was too flimsy and prone to it's own difficulties, why not something like a big, really good straw- that could be warmed up just a little with hot water first. Then screwed over the threads of the top of the piston shaft.
So I went to a 7-11 and so forth and found the straws too small. Then I found one of those cheap water "bottles" with the ribbed straws that have a cheap cap on the end. Sorry, I didn't take a picture of the bottle but the straw works perfectly. You can cut it down as desired and then lightly lubed. It is long enough to feed up through the seal with no damage. It screws right onto the threads and right up to the very slight shoulder after the threads that transitions to the final O.D. of the piston shaft.
So take a look and I think the rest is self explanatory:
Here it is screwed into place. The O.D. of the straw is just lightly less than that of the rod, but matches up nicely to the transition area. They should be easy to source.
Now a sufficient piston seal installer is the next challenge!
Is there a small engine piston ring compressor tool that is cheap and available? Those of you that have put pistons in engine block cylinders know what I mean...... a small bore 2 stroke piston tool?
greg moore
Leverwright
LMWDP #067
mogogear
Postby espressme on Sat Mar 24, 2007 9:10 pm
Hi Greg,
With your expertise in the camp stove field perhaps this would appeal.
Why not use the thin sheet metal from a "Oly" can. Overlap the seam and put a screw type hose clamp around it with the mechanism over the overlap. Shrink the end of the assembly to the inner diameter of the cylinder. Make sure the can is well de-burred and lubricated! The metal only makes a smoother transition along the inside of the hose clamp. A sheet of cheap "shim brass" or stainless steel would work as well. For the Enrico I used just the can material and a rubber band to reload the piston. I used a "tin can" on my " '49 Crosley Hotshot."
That is all the commercial shrinkers are. They have a thicker stronger metal because the iron piston rings are harder to compress. Also, the rings themselves are taking out the unevenness of the overlap from the thicker metal.
my 1¢
richard
richard penney LMWDP #090,
espressme
Postby wmfamily on Sat Mar 24, 2007 9:14 pm
Google for small engine ring compressor. There are several to pop up but the problem is that most will be too large.
What's the diameter of the piston?
John
wmfamily
Postby mogogear on Sat Mar 24, 2007 11:28 pm
Yep Richard,
That was the way I was thinking too- and of course use of an Olympia beer can would be appropriate :wink:
Pardon my C.A.D ( camera assisted drawing) attempt. A little emory cloth on the top and bottom edges and fold the edge as show, there will be no sharp vertical edge for the seal to be against. Insert in to the cylinder bore and with a little lube should slide right in.
greg moore
Leverwright
LMWDP #067
mogogear
Postby Fullsack on Sun Mar 25, 2007 12:05 am
A woman from Oakland, who rebuilt a Cremina, was at my house last weekend. She said, she put the seal and clip on the piston rod first, inserted it into the group and still had enough room to insert the clip compression tool to do its job. A neat trick, if you have the dexterity.
Doug Jamieson
http://www.fullsackjack.com/
LMWDP #017
Oh yeah, it's deliziosa!
Fullsack
Postby TUS172 on Sun Mar 25, 2007 12:52 am
Mo,
I noted that in your picture the piston rod threads came into a short bevel that transitioned to the full thickness of the rod. My '86 has no such bevel just a 90 degree shoulder that is treacherous to the seal. I was thinking that the next time I have to pull it I would just take it to the shop and bevel a nice shoulder with perhaps a bit more length and less angle after a 'stop' for the nut. Then perhaps the need for jumping through any hoops would be avoided.
Bob C.
(No longer a lever purist!)
LMWDP #012
TUS172
Postby mogogear on Thu Apr 19, 2007 12:57 pm
FYI-
While at Home Espresso Repair last week -Will confirmed to me that he had used a fine stone grinder to bevel the shoulder area on the piston rod. He said he has done this for years to keep from damaging the seals. His recommendation "seals" the deal in my humble mind. A easy modification.
Upon checking my two rods on the Cremina girls- one was done and one was not. Bench Grinder ( fine wheel ) and emory cloth made twins of them in no time.
greg moore
Leverwright
LMWDP #067
mogogear
Postby TUS172 on Thu Apr 19, 2007 7:26 pm
Well that confirms it... The next time I pull the group head it will be a done deal. Thanks for the update Greg.
Bob C.
LMWDP #012
TUS172
Postby bobcraige on Sun Apr 22, 2007 6:54 am
Actually, this is currently done on new Cremina's at the factory. It needs to be done on a lathe and not free hand as many piston shafts have been ruined this way.
Bob Craige
LMWDP #7
bobcraige
Postby timo888 on Sun Apr 22, 2007 2:25 pm
Is this clever device designed to protect the ring comprised of three pieces (a rubber ring, a metal washer, and a circlip) that fits into a cutout at the top of the group bell?
Is that ring meant to prevent rubbing of the shaft against the group? Or is it meant to augment the seal formed by the piston rings?
Regards
Timo
timo888
Next
