Hi All,
I am new to this forum and am happy I found it. I presently have a 2-group Cimbali Bistro at work that I am feeling responsible for and just bought a pretty old Microcimbali on a flea market. This is the old style with the aluminum pressure container, serial number 42101 (if anybody can tell me what year that is?). It hasn't been used excessively, but it has quite a bit of scale inside. I am trying to thoroughly clean it before putting it to use. I have gotten pretty far, go the lever/piston/spring assembly out, and also could open the bottom housing for the electrical stuff. I took off the nut from the threaded rod that connects the boiler housing to the base plate on which the heating elements are mounted. Now I would like to take the boiler housing itself off the base plate for cleaning and descaling. My questions are:
- Is this a good idea?
- are there any good usable limestone removers especially for aluminum?
- how do I get the boiler off the base plate. From the dteailed drawing, which I manage to lay my hands on, I can see that there is a gasket between the two. Nothing budges, though, even when I use gentle force. What is the trick? Ist it just stuck because of scale? Is ith screwed in? Any special tools or tricks??
Thanks,
Chris in Amsterdam
