itsallaroundyou wrote:The biggest problem I'm having is low shot volume, followed closely by the actual shot timing, not including pre-infusion, which is the third problem.
I'm attempting to use the Fellini pre-infusion technique, but it takes close to a minute until i see the first drops, at which point, i let the handle raise, and get a shot like the above. Using a coarser grind, speeds up the pre-infusion drop formation, but then i get no resistance in the handle for the rest of the pull, and get the dribbley shot.
Any tips, comments, or feedback is greatly appreciated
orphanespresso wrote:Been watching some youtube videos of Italian coffee bars using levers and the preinfusion is pretty long, but of course unknown machines.
[youtube]
THIS is what it is all about...true art!
I have a hunch that I might not have screwed the middle "nut" down enough in the group to compress the stack of gaskets, and might be losing a little water to inside the piston cavity. i need to take it apart to verify this. i'm about to post the restoration pics, so i'll edit this to add a link so you can see what parts i'm talking about (if you're unfamiliar).
itsallaroundyou wrote:In the video posted above (and in most others i've seen) the barista pulls the handle down with relative ease, and it stays down until manually lifted again. Mine does not do this since the spring is always pulling the handle back up. How can a spring lever stay down on its own? Mine has a little metal catch that will allow the handle to stay down, do these others work the same way?
