by grong on Thu Jul 30, 2009 11:00 pm
How does the espresso taste? I have had a Europiccola for about a month now, and having tried many dosing methods, I get my best results, including the most consistency, with a low dose (my Ponte Vecchio Lusso seems to do best with an overdose). With good distribution from my doser, I then level across with a chopstick—this is what I call a full dose. To achieve the low dose (as recommended by many others, including fullsack), I level across with a finger, grip side down, in two directions. This removes about a gram or so. Then I tamp.
With the underdose, the grounds do not swell to the point of touching the screen enough to leave any visible impression. A puck with good resistance during the pull will allow the portifilter to be safely removed in about a minute. With an full dose, a pull with the same resistance may require a several minute wait to safely remove the portafilter.
Perhaps try a low dose, and see how it does.
