For the first time I actually saw the OE temperature strip change color. According the to strip, the group hit 90C/194F.
This was after letting the machine warm up with the steam valve slightly open, two short water-only flushes, pulling a face-screwingly sour shot, another flush, and opening up the steam valve rather generously (about 20-25 mins all told).
Then I noticed the first bar of the temp strip changed color. Excitedly pulled another shot, which was still objectively pretty bad, but better than most of the previous shots--as in, it took a second, longer sip before I shuddered from the taste
Depressingly, I realize this might just mean I'm building a stronger tolerance for bad espresso, too.
Is there anything I should do with the pressurestat? I had never even registered the term pressurestat before getting this machine, so I don't even know how to get to it, let alone if and how to adjust it correctly, but shouldn't this have some effect on the temperature?
