Madroaster wrote:Green water...interesting. Wasn't expecting that. Citric acid never turned my pancakes green...
Madroaster wrote:I'll try the citric acid and see how that works first. What solution do you suggest? I have some, but I only have 4oz left.
narc wrote:Yellow tinge water? Have you pulled the piston assembly out for inspection. Check for coffee residue, mold at the piston base, if gunk found trapped between seals/gaskets maybe time to replace them. Hopefully it's just some residual water in the boiler, transfer tube that can be purged, dumped and flushed out.
