by DJR on Tue Mar 22, 2011 2:00 pm
Marcio,
I am not 100% sure that the frame of the Mini will take the additional force. You might want to run some tests. It is simple angle iron welded, but I can't tell if it is over engineered or close to the edge...! It is not particularly sturdy and if it bent it would probably ruin the plastic case as well. I suspect I could break it by hand if one end was in a vise.
Maybe since you seem to be an engineering sort, you should look into this. It wouldn't be hard to weld a triangle to the "L" so as to increase the strength; if it failed, that's probably where it would fail, though it would be possible to fail where the bolts attach the boiler to the "L"s.
Finally, as I noted in another thread, compressing the spring to get it onto the piston is very tricky. Keep in mind that not only do you need to compress it, but you also need to screw the piston onto the shaft, so if you are putting pressure on the end of the piston and trying to turn it a few turns, that will be very hard to do.
If I had to do it again, I would fabricate a special miniature spring compressing tool. It would be easy to make, modeled after the car spring compressing tools. Using pieces of wood or your hands is just not going to work, in my opinion, especially with an even more robust spring.
One thought that occurred to me is that a careful tuning of your grinder might get you the results you want in the cup... I don't want to discourage you, but....
Your friend,
dan
