davidl14 wrote:Jim at 1st line spoke to me reluctantly and I was informed that I was receiving one time help. To set the record straight, I have purchased hundreds of dollars from 1st Line including a Mazzer Mini, a brass La Pavoni, coffee etc. Apparently, the electrical connections are beneath the cover at the bottom of the black bakelite piece. Pressure adjustment is made at the top of the unit, near the plumbin connection, with a tiny recessed slotted screw. It's going to be quite a feat to connect the two wires from the heating element since the wires fit in groves with only enough room for the bare wires to be connected to the two screws since there is not enough room for a connector. With the connections at the bottom of the pressurestat, it's not going to be easy t make the connections. Any ideas?
Thanks for your patience with this novice.
Dave
If I understand you correctly, this is a pstat for the 2002 Cremina, and does not have spade connectors but two screws which tighten around bare wire. Is that right?
Your choice is to remove the connectors from the 67's wires, or buy another pstat, such as the C.E.M.E., that does have the spade connectors (there's a picture in
this thread). I personally would do the latter, and then try to sell the 2002 pstat here or on CoffeeGeek.
I believe there was a thread here in the past year where the spade connectors were identified as being convenient, but not as sound as bare wire in terms of the electrical demands placed upon the device. It might have been a remark made by H-B member
stefano65, but that could be memory playing tricks on me. He might have simply said it to me over the phone; I called him asking for advice when looking for a replacement pstat for my Oly Club.
Stefano is both knowledgeable and generous with his knowledge.
Regards
Timo
