by peacecup on Wed Aug 10, 2011 1:44 am
I found that having a steel-probe food thermometer inserted into the kettle was an absolute requirement. I'm fussy about keeping temperatures on the cooler side, and I pulled shots when my thermometer read 90C. I'm not sure how accurate that thermometer was, but it was precise, and the water was definitely well below boiling. I suppose a little cooling occurs between the kettle on the brew water too, but probably not too much.
I found that once I got the thermostat set it would stay quite close to where I wanted it. Because it's just a piece of spring steel, when it starts from cold each day it sometimes takes a little adjustment for the first shot though.
Reading and writing about the Caravel reminds me of just how amazing these little machines are. I'm currently using only spring levers because I have so many time commitments these days, but when things slow down i've got to get the VAM up and running!
PC
LMWDP #049
