boy_lah wrote:Ray - after your PID gets to 234'F/112'C...what is your routine from cold? Do you leave your boil 'on' after it hits 234'F/112'C but pull quickly or do you turn it off? Do you flush the head to warm it up, do you just go for pull from cold group? Or do you leave it essentially leave the boil on but only 'pull' when the temp drops back to 234'F/112'C? Mind sharing a bit more about your routine beyond the temp in your boiler being 234'F/112'C?
Finally, I assume time between the boiler hitting 234'F/112'C and pull is minimal ie. 3-6mins?
thanks
Clinton
With the PID controller, things function a little differently than a stock La Pavoni. I also have an adjustable pressure regulator (bypass valve) on mine, which allows me to fine tune the steam release balance point a little bit too.
Basically it goes like this:
I turn the machine on using the "II" switch setting. This bypasses the PID controller and uses the full 1000W heating element to heat up the machine. The PID controller still monitors the temperature and displays it on the screen, but it's out of the loop as far as controlling anything. The reason I heat the machine up on the "II" setting (which is there for steaming milk) is to take the load off the solid state relay, which normally the PID controller toggles on/off (which in turn controls the power to the heating element).
It takes the machine about ~ 2 minutes to reach 170+ degrees. At this point, I flip it back down to "I", which hands control over to the PID controller. From there, the PID controller stabilizes the temperature to 234.0 degrees.
I generally leave the machine sitting for about 5 minutes or 10 minutes on the counter. This gives the PID controller time to not only stabilize the water temperature in the boiler, but also for the entire machine (including the group head) to warm up to a more or less constant temperature. This helps reduce the differential between the boiler and group head temperatures.
Once the machine is up to temperature, the PID controller keeps the water in the boiler at 234.0 degrees (or whatever target temperature you set) to within 0.1 degrees. The PID controller cycles on 1/4 of a second (to inject heater) for every 2 seconds. So you can think of it like a 25% duty cycle, where the heating element comes on and goes off - just enough to balance the water temperature.
Before the first shot, I usually pull some water through the group head (sort of like the reverse of a cooling flush on an HX machine). Then I pull the shot. During the pull, the PID controller is still keeping the temperature at 234.0 degrees, although sometimes it will maybe move 0.2 degrees (although I usually don't pay a lot of attention to it, since I'm focused on how the extraction is going).
The group head temperature is pretty constant. Because the machine is constantly pinned to 234.0 degrees, it tends to level out the temperature of all the components of the machine, including the group head. So you never really get into a situation where anything over heats. If something were to over heat, it would impact the water in the boiler, which would cause the PID controller to cut power until the water temperature dropped back down to the proper level. So you can think of the PID controller as not only controlling the temperature of the boiler water, but also controlling the temperature of the overall machine (at least to some degree, since everything on the machine is connected).
As long as there is water in the boiler, you can leave the machine on all day and it just stays at whatever temperature you program. With the adjustable pressure regulator, you can increase the spring tension to meet (or slightly exceed) the steam pressure inside the boiler; this achieves a perfect balance between the two and prevents the machine from hissing steam. Except for when I'm steaming milk, the machine runs totally quiet and doesn't make a sound.
For steaming milk, I flip up to "II", which takes the PID controller out of the loop. It takes about 20 seconds to go from 234 degrees to 250+, which produces more than enough steam pressure (around 25 PSI). What I usually do is flip the machine to "II" right as I'm starting the pull. By this time, the water in the group head is heading through the puck. As I'm exacting the espresso, the machine is racing up to 250 degrees. So just about the time the shot is done, the steam is ready to go.
Once I'm done steaming milk (if I'm making a latte), then just turn the machine back to "I" and the PID controller takes over again and brings the temperature back down to 234.0 degrees again (or whatever the set temperature is). It only takes a minute or two for the machine to drop back down to the target temperature typically (especially if you bleed off a little steam).
That's basically the routine.
Ray
