I've been asked what happened to the project to rebuild my Conti Prestina. What's happened is that the functional part of the rebuild was completed almost two weeks ago. I brought the Conti in from the garage, connected it to the water line, tightened a couple bolts to stop a few leaks, and started pulling shots of espresso. The first two shots were sent down the drain, but after that they've at least drinkable, and often very good.
The new handles ordered from Conti in Monaco should have been here at least a week ago, so I was waiting until they were installed to post some more photos. Today I finally located the parts, but unfortunately it looks like they won't be delivered for a least another week.
So for all the Conti fans out there I'm posting a few more photos, but not of the machine with the panels installed. That'll have to wait for the new handles!
First, here's a closeup of the new Sirai pressurestat and the new pressure relief valve.
This shows the new lights. I added the yellow one to show when the element was on.
This shot shows the connection to the heating element. Notice that the element exits the boiler end plate thru two small holes. It should be fairly easy to custom build a new element, if necessary!
This photo shows the new switch, the 10 Amp fuse folder I added and also the barrier strip used to keep the wiring neatly installed.
The last two photos show the insulation for the boiler and a sneak preview of the newly powder-coated side panels. According to the parts diagram I got from Conti the boiler was originally insulated but the insulation had long since been removed. I just used duct insulation from Lowes.
