Recently started a thread asking for advice about gas to electricity conversion of Faema Lambro or Conti Empress, but thanks to fellow-member Zeb/Pascal I am now the happy owner of a Conti Empress. She landed in Sweden a couple of days ago, very carefully packed, surviving the handling of various freighters..
The machine has been partly restored and converted from gas to 220V by Zeb, with few restoration issues left to be solved, mostly replating and finding a light bulb for the indicator light, that I've now found a source for. The machine is overall in a very good condition, and I was thinking posting more about the usage including pics, once it is properly hooked up to water.
In the meanwhile I have a few questions/observations that I would like to hear other Empress users opinion about.
I managed last night to make a provisional waterhook up, via the garden hose, while waiting for fittings and an anionic filter to arrive, mostly to do a quick test run.
The machine first didn't heat up, until I realized that the false pressure built up by filling the boiler prevented the pressurestat from activating. After bleeding fp, the machine went up to 0,9 bar with no fuss and no leaks.
Made three shots, the first too quick extraction and sour, already second time, very spot on, just used the same grind as on my Valentina/BFC and adjusted volume and tamp a bit.
Issues: After proper shot volume, the machine keeps dripping for a long time with a volume more than an extra double shot, and when trying to release the PF I felt a resistance known to me from my Pavoni Europiccola, indicating risk for "Sneeze"
I waited a while, like 2 min, and gently released, wiggling a bit on the way out and the pressure escaped without blowing out ground coffee allover the place.
Obviously since this is a dipperfed lever with no solenoid, this could be more or less expected I presume, but is that other Empress owners experience as well? How do you manage? Do you press down the lever a bit to alleviate the pressure before removing PF?
It seems to me that the internal volume of the group must be much bigger than what is needed for a shot, and that is the extra volume dripping out once you've drawn your normal shotsize, leaving you with a wet puck and pressurized group. While pressing down the lever, with empty PF the speed with which the water comes out of the group is in my eyes very fast so you either have to do very short preinfusions if you don't want excessive water volume in the group which would then allow you to release the PF quicker without a sneeze, or find some way of restricting the flow of water into the group. I haven't opened the group yet, so don't know the internals or the diameter of the feeding tube which is of cause also important.
Another thing I noticed is that the dispersion screen is loose, you can press it 2-3 mm upwards and side to side, is this normal for the Empress, or due to a changed unoriginal screen or maybe the new PF gasket?
The pressurestat setting just below 1 bar in in correspondence with what Doug Garrot shows in his video from OE, do you other guys have this level as well? I can say, than steam power is in no way compromised at this setting, it is a wild horse compared to my BFC/Valentina. I saw in Kitts photos that he changed the steam tip , maybe to one easier controlled?
I have sought up an down various coffee forums for user experiences on the Empress, these are remarkably few, but hopefully this could be an initiative to share more knowledge on cup- and user aspects as well.
Hope you chime in
Best regards
Ulrik
