Conti CC100 PM, Can't Source One But Here's A Peek - Page 2
You are indeed correct the cc100 does have a manual fill lever on the front, I am away at the mo but will get into a strip down for you guys when I get back.
levers levers levers, is there any other way?
- cuppajoe
Nicely done design, they did a good job of integrating the group shrouding into the main body. Looking at it you'd almost think it was from the late 50's or early 60's and would consider it over a classic for a commercial setting where it would be front and center.
Any pics of the front side?
David - LMWDP 448
Cma Astoria use a similar group, i have make this video in their factory
Hi Coffeechap,
Can you tell me how many minutes your machine takes to get to proper operating temperature?
How bad exactly is the tipping-forward behaviour of this machine?
Using the same coffee, how do shots compare with the GS3 nearby and the Londinium?
Is that the sightglass behind the steam wand in one of your photos?
Many thanks,
Paolo
Many thanks,
Paolo
- sorrentinacoffee
I like the look of this machine- not a stainless box- has to be good. Would love to try one out. I imagine you could make a base with ballast in it to hold it down... look forward to an more info if anyone has any?
Awesome, can't way to see more about it...can't imagine why it would tip though...lot of empty space in the back?
- drgary (original poster)
The group assembly weighs 18 lbs. These types of groups are usually assembled in multiples on larger machines with horizontal boilers that hold a lot more water. I don't think it's a difficult problem to solve, though. You could fasten it to a base or add ballast as was suggested above.
LMWDP#308
LMWDP#308
It would be great to hear from someone else who has one of these machines. To me the concept of the CC10PM (with the prestina group and the manual water-fill) melds the old and the new into the one machine....but I could be wrong...
Is there anyone else out there who can shed some light on this machine?
haven't been at the workshop for a while but will be there thursday and will get some more photos up
Hi Coffeechap,
Have you had any luck with any photos? I for one would really like to see inside this machine.
I would also like to hear anything and everything that you are able to share about it.
How good do you think this machine is?....how does it compare to other levers that you have used?
Cheers,
Paolo
Cheers,
Paolo
