by bill on Wed Mar 19, 2008 9:21 am
Hi Ted,
I've had a commercial lever in my home for about three years and have been completely satisfied. The advantages I've seen are 1)the machine's always on and ready to turn out a quick espresso, 2)the convenience of having it plumbed in to the water supply and a drain will spoil you very quickly, and probably the most important 3)the machine produces a good espresso every time with a minimum of fuss. As Dr Jim, another member of the forum, once said about his Conti (and I quote from memory) "you can just walk up, pull an espresso, and enjoy". I'm sure that's not an accurate quote, but you get the idea!
The disadvantages are 1)depending on the machine they can take up more counter space than the typical home machine, 2)most use 220 volts so that may an issue with some folks, 3)installation is more complicated due to the plumbing and electrical requirements, and 4)since the machines are on 24/7 the cost to operate is higher than a home machine.
All three of the commercial lever machines I owned have used Sirai stats. The noise comes from the snapping of the electrical contactor. Some seem to be much louder than others and I don't know why unless it's due to the way the stat is mounted. I have noticed that the newer Sirai stats have plastic covers rather than the metal covers used on the older ones. That probably makes the newer ones quieter. I have to be standing next to my Gaggia to hear the stat so noise is not an issue.
Good luck!
Bill
I wasn't born in Texas, but got here as fast as I could!
