So... after a couple of exchanges with Doug from orphanespresso, I had several O rings and a couple of U gaskets in hand and went to work. He also supplied instructions and some very nice 3M adhesive silicone (?).
First I slipped on the U gaskets...
They were tight in the cylinder and did not turn on the piston but after applying Dow 111 the cylinder fit seemed a bit loose. In operation the U cups leaked downwards at 0.2 Bar and by the time the boiler element cut out at 1.25 Bar I had a cup of water out the bottom, 2 - 3 drops out the top. Top stable at 1 drop per motor cycle - bottom did not seal itself after ten cycles so I presumed to quit and try O ring W/ Tape packing.
After some testing I put the lower ring (which went on to EXACT match of outer diameter to the U cup without packing) with 1 wrap of tape with zero stretch and replaced O ring. The upper O ring which seems to bear less load I put the tape on with some 'strech' to reduce the sectional area.
This combination holds easily to 1.25 bar (has bounced to 1.4bar) W/ no seepage.
Success on the gaskets! Thank you Doug!
The motor seems happier now that it used to - but that could be the residue of the Dow 111. The Crema is (after adding thickness to the lower gasket) slightly better that it used to be - but this machine has never supplied much. I should be looking to other ways to improve that I guess, but the nature of this mechanism does not allow for adjusting the 'pull'. I will need to consider this further.
So for anyone interested... I attach a link to a video clip of the little motor that could, kinda...
http://www.youtube.com/watch?v=B-JWq5vfLscI rather hate the idea of closing her up again, I have grown fond of the brass uppers and piston rod!
