Chert wrote:When I started with the CMA group, I heard somewhere that every six months, the piston seals should be changed. How often would you suggest they be changed?
Chert wrote:One of my groups seemed to work well, but I took out the piston/spring assembly and learned that I had the seals oriented exactly in reverse of correct. There was some moisture about the brew chamber, but relatively little.
Chert wrote:I replaced the seals in correct orientation. It worked well but there were occasional knocks during late phases of extraction from that group which suggested to me that a seal was allowing intermittent pressure release.Now that group has failed, obviously a piston seal has slipped and the lever will not move smoothly. Should I expect that new seals will resolve the problem or should I also change out the seals between the group brass chrome lined insert as well?
