1) My primary concern for the moment, though, is its exterior appearance. After 20 years in a garage, the brass base has plenty of splotches and blemishes and discolorations. There doesn't seem to be any of what I would consider to be rust, though of course I'm not 100% sure of that. It's still smooth to the touch, and relatively shiny with a nice amount of luster, and certainly pleasant to look at from a few feet away. But up close, some of the splotches look like perhaps the protective lacquer might have been compromised, and I am concerned that any minor visual defects on the surface right now might later rust or transform into serious issues that actually interfere with the operation of the machine. I took a few photographs just to illustrate what I'm talking about, see them below:
(((EDIT: Photos # 1, 2, & 4 uploaded directly to this post)))
I have tried to buff this stuff out with hot water but to no avail.
Has this been experienced before, and if so, what product or process would clean or polish the exterior? Could the lacquer be an issue, and should it be stripped, reapplied, and if so, how? Or is the appearance simply an uncorrectable cosmetic effect of 20 years in a garage, and nothing can be done to shine it up? I am fine with how it looks (it was free to me!) provided that the cosmetic imperfections do not turn into operational problems.
Some secondary questions:
2) I have already descaled it, but it seems like the machine would benefit from a backflushing regimen with the "Joe-Glo" solution. But I can't find any blank/blind/backflush discs of size 49mm that would fit a pre-millennium Europiccola portafilter. Is this machine even capable of performing a backflush or are there alternative procedures that should be used to flush out the group head of stray coffee grinds and oils? Where would I get a 49mm blank/blind/backflush disc, since I cannot find one of this diameter on any of the major spare parts websites?
3) I would like to remove the double spout from the portafilter and replace it with a single spout, but cannot unscrew the spout at all. After 20 years, it is very firmly screwed and stuck to the portafilter. I need some serious torque, but doubt that a wrench would work. Any ideas about getting the double spout off? Could it be soaked in some sort of solution to loosen it up?
Thanks for your help.
