entropyembrace wrote:So I'm wondering....is there an easier way to get behind the shower screen on the La Pavoni than disassembling the entire group head? I've only seen people take everything apart to do gasket changes and restorations....and the shower screen is never first.
Is it necessary if I'm not changing the gaskets? what are peoples cleaning routines for the La Pavoni?
RayJohns wrote:On my La Pavoni, I strip down the group head about once a month.
uscfroadie wrote:Ray,
If you move to Dow 111 from olive oil you will not have to do this once a month. I used olive oil out of necessity about two years ago when I was in Iraq because I did not have and could not find some Dow. After two weeks my machine started smelling a bit, which just so coincided with the arrival of a few small tubes of Dow, so I serviced the grouphead properly and have never had the smell since. Using the Dow will easily extend you to three months...and your machine won't smell. Besides, you can get a tube that will last a lifetime for about $10.
As for descaling, if you are doing it once a month you are either wasting time, using really poor water, or you just like to tinker with your machine. Nothing wrong with doing it that frequently, but it should not be required that often.
The steps you listed are spot-on, but to find out if you need to descale, just listen to your machine. It should be nearly whisper quiet when heating up. If you hear mild groaning, your machine could use a descale.
Hope this helps all of you attain many years of service.
RayJohns wrote:On the olive oil, I use such a minute amount, I don't think it will make much difference either way. Sometimes I just use a drop of water also instead. Just anything to give the group head piston gaskets some lubrication.
yakster wrote:So far with my Gaggia Factory (~ = La Pavoni Pro) I have just been using a Pallo coffeetool brush, a wash bottle, and a microfiber cloth to clean the group and dispersion screen. That and the portafilter wiggle to dislodge any stuck grounds.
I haven't pulled the screen yet, but feel that I should soon, so I'm also interested to hear responses on this thread.
