Ursula is nowhere near as easy to work on as the earlier Caravels. Dr. Salati's ideas about a machine that is easily serviceable by the owner seem to have faded as the design changed hands. In order to remove the piston from the group head, you must completely remove the kettle and since the heater is attached to the bottom of the kettle, and the thermostat is attached to the side of the kettle and to the indicator light on the front of the case, you have to undo four machine screws that hold the plastic kettle surround in place, then four screws that hold on the front plate that covers the cylinder, lift the kettle slightly so you can unhook some wire terminals, then remove the kettle so you can spring out the lever arms so you can pull the kettle out to finish removing the front plate, which is what normally keeps the pin that secures the piston assembly in the cylinder in place. Once the front plate is removed, you simply slide the pin out and pull out the piston assembly.
The piston and seals are identical to the Caravel Type II, with a hollow piston and o-ring seals in the walls of the cylinder and the tiny o-ring sealing the piston on the downstroke and letting air out when drawing water from the kettle (and also letting air in on the upstroke, which is why Fellini moves and multiple pulls have less tendency to disturb the puck on the Caravel - there is little to no vacuum created in the cylinder on the upstroke because the small o-ring unseals as soon as the piston starts getting pulled up). All the seals were as clean and flexible as new, so I applied a little Dow 111 and put them back in place. I guess the spare set I ordered from Orphan stays in the supply drawer against future need.
Cylinder bottom before cleaning
Cylinder bottom after cleaning
Cylinder top before cleaning
Cylinder Top after cleaning.
And in parting, if I had a camera with better depth of field than the point and shoot I was taking this with, I would have pulled a shot on the other Caravel into one of my 2 oz. Bodum borosilicate espresso glasses, done a little creative lighting, put the shot at the far end of the cylinder, and entered it in the barista bling contest.
