Caravel Pulls
Postby GVDub on Fri Mar 20, 2009 11:40 am
So after having seriously choked the machine yesterday morning and not having time to try and diagnose, I got up early today to try again. It takes long enough to get it to heat without a step-up transformer that I'm doing the 'nuke the water to boiling, then pour it in the tank' approach. One of the big advantages of the Caravel for this is the heating element lets you turn it on with an empty tank without danger of harming the element, so that by the time the water boils in the microwave, the tank is preheated sufficiently that it doesn't behave as a heat sink for the heated water you're adding. This is all Monday's roast of a 1:2 blend of Yemen Mokha Mattari and Sumatra Lake Toba 19+ Extra Bold. Here's what I got:
This is a test of the new PeDe grinder I picked up from Ebay. Not quite fine enough yet, so the pull was a little quick, but not bad.
The no-name grinder from Orphan. Trying for a double. Probably a little cool (~196°F), as I was tweaking the thermostat on the Caravel. Decent. Excuse the focus, but clear glass is rough on a point and shoot autofocus.
Best shot of the morning. 201°F, no-name hit the grind right on. It's a ristretto shot with a Fellini move and single pull. Very tasty. First time I've ever really tasted any floral notes in a shot I've pulled myself.
"Experience is a comb nature gives us after we are bald."
Chinese Proverb
GVDub
Postby espressme on Fri Mar 20, 2009 12:30 pm
Congratulations! She is a honey and does her best to satisfy.
-Richard
richard penney LMWDP #090,
espressme
Postby IMAWriter on Sun Mar 22, 2009 2:19 am
GVDub wrote:So after having seriously choked the machine yesterday morning (etc
[snipped] .
I TOLD you not to choke the Caravel, but YOU DID IT anyway!!! :roll: :lol:
It's like the first time I tried using a microwave oven, back in 19hundred and something....
Had to do bacon, right?
Almost set my house on fire!
Enjoy the 'spresso, and go easy on the little orange miss.
Rob
LMWDP #187
www.robertjason.com
IMAWriter
Postby GVDub on Sun Mar 22, 2009 4:36 am
IMAWriter wrote:I TOLD you not to choke the Caravel, but YOU DID IT anyway!!! :roll: :lol:
I try not to make it a habit of abusing those I care for, but I was following the advice that Orphan has up in their Hand Grinder User's Manual
Turn the lever until the burr is tight enough to lock the handle—this is the point of maximum tightness. Now, back the lever counter clockwise about 1/4 turn, or until the handle will turn with no extreme resistance...the process now is much like dialing in any grinder for espresso—add your dose of beans, weighed or measured and try making a shot. Ideally you will choke the machine on the finest setting of the mill. Loosen the burr about 1/4 turn of the burr adjustment and try again.
Besides, I know that if I ever did anything to hurt Clarabelle, the fine citizens of this august forum would descend on my home en masse armed with custom Reg Barber tampers and dissecting needles and proceed to give me what for. I hate it when that happens.
Chinese Proverb
GVDub
Postby IMAWriter on Sun Mar 22, 2009 1:46 pm
GVDub said "Besides, I know that if I ever did anything to hurt Clarabelle, the fine citizens of this august forum would descend on my home en masse armed with custom Reg Barber tampers and dissecting needles and proceed to give me what for. I hate it when that happens."[/quote]
Speaking for the group I say.............
Muhahahahahaha :lol:
Rob
LMWDP #187
www.robertjason.com
IMAWriter
Postby GVDub on Sun Mar 22, 2009 1:54 pm
They say when you stop learning, you start dying. At the rate things are going, I'm likely to be around for a long time.
Well, this morning, I learned just how easy it is to disassemble the Caravel. I ground too fine, tamped too hard (with my improvised ibuprofen bottle tamper) and blew out the bottom seal. The ease of repair and maintenance is one of the things that drew me to this particular machine, and I have to say it paid off today. Drain the boiler (well, stick a series of cups under the head to catch the water pouring out past the unseated seal), remove it, pop out the piston and the screen (since the bottom seal is much more accessible from the screen end of the group head), rinse out the boiler and cylinder to make sure that there are no grounds that made their way to where they shouldn't be, rinse the seal and reseat it, then put the whole thing back together. Elapsed time, under 5 minutes. If I'd thought to put water on to boil as I started the job, I would have been pulling my next shot pretty much as soon as I'd finished with the repair. It was no big deal, which, I think, is exactly why Dr. Salati designed it the way he did.
I had the epiphany this morning (and epiphanies are so appropriately had on Sunday mornings) that my enthusiasm is getting the best of me and I need to take a step back. I'm trying to rush learning the grinder and the machine at the same time, making the classic newbie mistakes of altering too many variables at once, then having no idea which one made the difference - changing coffees, changing grinds, not paying as much attention to temperature stability, not developing consistency in my approach, either physically or mentally. I'm just so damn eager to learn that the eagerness is getting in the way of the lesson.
One of the things that makes it harder is not having a solid reference point. Most of what I've pulled from the Caravel so far is vastly better than any espresso I've gotten from *$, Coffee Bean, or pretty much any of the independent places I've been to here in the San Fernando Valley. As an example of the latter, while getting the car serviced in North Hollywood yesterday morning, I stopped into the Independent Coffee stand at Magnolia and Lankershim. They've got a two group Astra automatic and, when I asked about the espresso blend, made a big thing out of how the owner roasts his own beans. I asked for a single ristretto shot, and they packed up a double basket and gave me what came out of one spout, bitter from too much heat and over-extraction. At any rate, all this makes my destination a little fuzzy, as if I've planned a vacation to Texas, but don't know exactly where in Texas I'm heading - just Texas. In trying to decide if I'm headed for the hill country, Austin, or the bayous of southeast Texas, I signed up for the cupping class at Jones Roasters in Pasadena this coming Wednesday, just to start calibrating my palate a little more finely.
The third shot of the day (fourth, if you want to count the choked shot that blew the seal) was the winner, though. Tuesday night's roast of SM's Liquid Amber, ground just a little coarser than the choked shot with a tamp that barely kissed the basket enough to polish the top, came out with that melted butter mouth feel and those tobacco, smoke, and caramel notes Tom describes. That trip is, I think, coming into better focus.
Chinese Proverb
GVDub
Postby peacecup on Sun Mar 22, 2009 2:26 pm
Try changing one variable at a time, i.e., grind, dose, tamp, and beans. Stick with the same roast for a few batches - you'll probably need to tighten the grind every couple of days.
I personally like the Caravel basket full to the top, after a 5-10 lb tamp. If it stalls, don't pull the shot, but loosen the grind 1/4 turn.
PC
LMWDP #049
peacecup
Postby GVDub on Sun Mar 22, 2009 8:32 pm
The last pull of the day today, a 1:2 blend of Yemen Mokha Mattari and Sumatra Lake Toba 19+. 200° by the temp probe. Portafilter heaped with a couple of settling taps along the way, leveled and a polishing tamp. Fellini pre-infuse and a single pull for a .75 oz or so ristretto. Smoothly unctuous mouth feel, heavy body, leather, tobacco, spice, and chocolate, with just a hint of fruit from the Yemen, which was roasted just to the edge of SC. Not a lot of crema, but it tasted just amazing.
Chinese Proverb
GVDub
Postby IMAWriter on Mon Mar 23, 2009 1:40 am
My Caravel shots were also a touch less crema-rich than my now Cremina, but no less tasty.
Enjoy.
I enjoyed Brazilian SO's in the caravel...more crema and body for sure.
Rob
LMWDP #187
www.robertjason.com
IMAWriter
Postby GVDub on Mon Mar 23, 2009 1:48 am
IMAWriter wrote:My Caravel shots were also a touch less crema-rich than my now Cremina, but no less tasty.
Enjoy.
Rob, I just got 5 lbs of the Brazil Ipanema Tree Dried from Sweetmaria's to try as a base for an espresso blend. I'll have to try it as an SO, too.
Chinese Proverb
GVDub
Next
