peacecup wrote:I was faced with premature blonding during my early Caravel period. I solved it by filling the basket ALL THE WAY TO THE RIM, AFTER TAMPING (make the grind coarser before you try this).
Since I don't yet have a proper tamper, here's what I'm doing:
I grind 14 grams of coffee, load it from the hand grinder drawer to the scraper/scoop/doser I got from Orphan, and dose it into the portafilter, tapping to settle twice along the way (about 2/3 full and when it is just mounded over the top). 14 grams gives me slightly mounded after finishing the dose following the second settling tap. I then use the scraper blade to press the coffee flat into the portafilter and level off the top. This is probably equivalent to a light (5-10 lb.) tamp. I'll then use my not-quite-but-almost fitting ibuprofen bottle to do a little nutation and polishing tap, leaving me with about 2mm headroom. then I pull the shot, following pretty much your procedure. First partial pull for pre-infusion until I get a drop, gently raise the lever to refill the cylinder, then either a full pull for a ristretto or a half-pull, raise the lever again, and a full pull cutting off at blonding (which normally gives me somewhere between 30-45ml or 1-1.5oz. if you want to go non-metric).
