I got home and realised after starting it up that the heating element was blown. The guy set me up, poured boiling water into the kettle before I got there and did not even tell me the element was gone.
Well after getting over the injustice of the whole thing and realising I would have bought it anyway I decided it was a new project. So I searched and searched for elements without success. They apparently are not easily found.
But I got an idea.
Perhaps an iron might work. Searched for compact irons and finally found a 420 watt travel iron that seemed to have the same footprint as the bottom of the kettle.
And with a little fiddling and grinding.
So now the whole thing is back together and is heating up fine, though slow. I will time the heatup with a half full tank and report back in a day or two.
I have a few questions.
1. I rewired the plug to fit a standard 120 us volt and noticed the old plug had a three wires attached to the machine one being the ground (yellow) yet at the end there was only two prongs entering the wall. So was this machine grounded originally?
2. What PID configuration can I use to maintain a constant temperature and how would I put this all together?
3. What is this? It is in line with power to the element/travel iron and sits against the inside vertical wall of the base.
Look forward to any input.
