Caravel, acidic espresso.
Postby Lvx on Mon Feb 02, 2009 9:09 pm
Hello to everybody! :D
I have a Caravel,( the orange one, which should be the 3rd series) which makes me crazy.
Using the same coffee as with the Elektra Mcal (taste perfect) , the taste is terribly acid.
Any suggestions to help me? :roll:
Lvx
Postby espressme on Mon Feb 02, 2009 10:34 pm
Hello Lucio,
First, let me welcome you to H-B. You have a really great home machine in the Caravel! And a wonderful menagerie beside it!
FWW, There will be others chiming in but: get the water hotter! When i had use of a Caravel, I would pour hot water (first roiling: about 204°- 206°F, water is at full boil at 209°F at my altitude above sea level) into the kettle and pull a couple blanks to get all to temperature for the best single shots coffee I have ever had. After the boiling water, the heater would happily keep the machine at the correct set temperature.
YMMV
If I did not already own a menagerie, I would have kept her!
Cheers
-Richard
PS a simple kitchen thermometer that has a temperature probe with a long cord to the actual sensor will help you nail the temp in the kettle, and in your boiling pan for a preheat. A thread on temperature with some photos of some thermometers:
Click Here
richard penney LMWDP #090,
espressme
Postby Lvx on Mon Feb 02, 2009 11:52 pm
Thank you Richard . Tomorrow i'll try it. :D
Lvx
Postby Lvx on Tue Feb 03, 2009 5:45 pm
Simply, logic, perfect.
so few degrees , so many trouble :D .... solved.
Lvx
Postby espressme on Tue Feb 03, 2009 7:58 pm
Congratulations and post from time to time and don't forget to join the Lever Machine World Domination Plot!
Click Here
Many Happy Pulls to you!
-Richard
espressme
Postby hbuchtel on Tue Feb 03, 2009 10:51 pm
Nice! :D
Just curious, what coffee are you using?
Regards, Henry
LMWDP #53
hbuchtel
Postby Lvx on Tue Feb 03, 2009 11:09 pm
Indian Monson Malabar 75 % , Robusta 15% (maybe brazilian).
Difficult to set the correct grinding, due to the oily beans, but great taste! :wink:
Lvx
Postby IMAWriter on Mon Mar 30, 2009 9:18 pm
hbuchtel wrote:Nice! :D
Regards, Henry
I was just about to ask that.
(Caravele-ers, please excuse a quick ecursion OT)
I've read the Monsooned Malabar/Robusta. About 60% of Josuma's Malabar Gold, but where's the sweetness?
Lucio, would you have any objections to adding either a nice nice chocolatey Brazilian, or a Cleaner Sulawesi? (to keep your blend in the samr general vicinity)????
Your getting huge crema, I'm sure, but I wonder if your getting a nice sweet aftertaste.
You'd know, of course.
Which Robusta?
Edit...whoops, justy caught the "Brazilian" after the Robusta. Are you sure?
Rob
LMWDP #187
www.robertjason.com
IMAWriter
Postby Lvx on Mon Mar 30, 2009 9:58 pm
Well, i'm using this mix since it's the best (quality/price)with the Elektra mcal.
Every time i try to change % or type of coffee i get mad with the grinder because i need to pull at least 15 cups to find the correct settings. So i prefer to fix it as soon as i can.
I've started 1 week ago my own home roasting so i will perform some other experiments very soon.
I will talk with my coffee beans "pusher" :mrgreen: to understand which coffe i use and how i can improve the blend.
thanks for your appreciated suggestions :wink:
Lvx
Postby IMAWriter on Tue Mar 31, 2009 12:39 am
Lucio...I probably should have mentioned this in closing..."if it tastes good to you...it IS good."
Go with what works for you.
Heck, go with 50% Robusta, and you could probably fly here, no airplane needed. :lol:
Rob
LMWDP #187
www.robertjason.com
IMAWriter
Next
