I went ahead and bid on a damaged Elektra Micro Casa a Leva with matching grinder (also damaged) and won the auction (item #: 310051016285)
I think I'm gonna need lots of help and advice to bring this back into a safe operational unit. It was described as having a bent steam wand. I was hoping that the wand's being bent would be a simple fix to 'rebend' back into shape. Now I'm not sure as it appears the boiler has been dented also. The boiler also seems to be coming loose and it feels that it is about to separate from the base.
I've also looked at other pictures of Leva's and the base seems to be bigger and it also doesn't have the screw/bolt in the middle of the drip tray - is this a variant of the Elektra Leva?
1. How do I tighten the boiler onto the base?
2. Is there a way for me to undent and move the wand back into a usable condition - or should I just plug it up and not bother making any cappa's? I have an Oscar as well as a europiccola so I can always use either to make latte's and cappa's.
I'd like to be able to fill it up and power it up to check it's operation but I want to check with the experts here to see if there's something else I should do first.
Any tips and advice from fellow LMDWP members would be appreciated!
Cheers,
Caesar
